[Qgis-developer] Problems upgrading nightly in Ubuntu 14.04
Alexandre Neto senhor.neto at gmail.com
Fri Feb 12 14:35:17 PST 2016
Nice! I have been banging with my head because of this for a while!
DelazJ <delazj at gmail.com> escreveu no dia sexta, 12/02/2016 às 21:44:
> Thanks Jeremy, it works!
> 2016-02-12 20:39 GMT+01:00 Jeremy Palmer <JPalmer at linz.govt.nz>:
>> > Décompactage de qgis-plugin-globe-common
>> > (1:2.13.0+git20160212+bcc8e2a+20trusty) sur
>> > (1:2.13.0+git20160209+964ae1f+20trusty) ...
>> > Traitement déclenché pour  mime-support (3.54ubuntu1.1) ...
>> > Des erreurs ont été rencontrées pendant l'exécution :
>> /var/cache/apt/archives/qgis_1%3a2.13.0+git20160212+bcc8e2a+20trusty_i386.deb
>> > E: Sub-process /usr/bin/dpkg returned an error code (1)
>> > 2016-02-12 15:52 GMT+01:00 Jürgen E. <jef at norbit.de>:
>> I did this to resolve the issue:
>> sudo dpkg-divert --remove /usr/bin/qgis
>> sudo dpkg-divert --remove /usr/bin/qbrowser
>> I think it was related to this change:
>> https://github.com/qgis/QGIS/commit/8b054e6661c672b10f14afc661bc16ad83c6e064
>> Cheers
>> Jeremy
>> This message contains information, which may be in confidence and may be
>> subject to legal privilege. If you are not the intended recipient, you must
>> not peruse, use, disseminate, distribute or copy this message. If you have
>> received this message in error, please notify us immediately (Phone 0800
>> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
>> accepts no responsibility for changes to this email, or for any
>> attachments, after its transmission from LINZ. Thank You.
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160212/63edadce/attachment.html>
