[Qgis-developer] Problems upgrading nightly in Ubuntu 14.04
Jeremy Palmer
JPalmer at linz.govt.nz
Sat Feb 13 13:10:05 PST 2016
Hi Jürgen,
> See also https://lists.osgeo.org/pipermail/qgis-developer/2016-February/041339.html
> I didn't mention it again as I wanted to verify that the fix works this time -
> which 5f310a didn't.
> Declaring the conflict as in 5f310a was supposed to remove the diversions.
> Unfortunately the diversions were only removed when the package was removed,
> but not on upgrade. So the diversion would stay. And the upgraded version
> didn't know about diversions anymore and hence would not even remove it on
> removal of the package anymore.
> 7489af8 hopefully does fix it - it does here when upgrading from 2.12 - but
> once the diversion is removed manually that can't be checked…
Thanks for the more robust fix.
Cheers
Jeremy
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
