[Qgis-developer] Templates for issues and pull-requests
Matthias Kuhn
matthias at opengis.ch
Sat Feb 20 06:45:02 PST 2016
Hi Alexander,
I recently started to write a CONTRIBUTING.md [1] file which is also
shown when opening a PR. But it's always one click away and I think
moving this to a PR template would be much better.
It will probably reduce the roundtrip if when creating a PR every
contributor is reminded of
* Did you run prepare-commit.sh?
* Have you written a unit test where applicable?
* Did you create .sip bindings?
* Did you write API documentation?
* Is your commit message meaningful?
* Did you add [needs-docs] or [feature] tags to the commit message and
include enough information for documentors in the commit message?
Is there more information that should be included?
Would you mind setting up a draft for it?
Matthias
[1] https://github.com/qgis/QGIS/pull/2581
On 02/19/2016 07:45 AM, Alexander Bruy wrote:
> Hi all,
> recently GitHub introduced templates support for issues and
> pul-request, see [0, 1].
> Maybe we can utilize this functionality in our repos. For example,
> issue template
> can be used for the QEP repository and PR templates for main QGIS repo as
> well as for QGIS-Processing and maybe some other.
> Opinions?
> [0] https://github.com/blog/2111-issue-and-pull-request-templates
> [1] https://help.github.com/articles/helping-people-contribute-to-your-project/
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160220/3454205d/attachment.sig>
