[Qgis-developer] Templates for issues and pull-requests
Alexander Bruy
alexander.bruy at gmail.com
Mon Feb 22 01:57:03 PST 2016
Hi Matthias,
you can find my attempt to create pull-request template
in my fork https://github.com/alexbruy/QGIS/commits/pr-template
2016-02-20 16:45 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi Alexander,
> I recently started to write a CONTRIBUTING.md [1] file which is also
> shown when opening a PR. But it's always one click away and I think
> moving this to a PR template would be much better.
> It will probably reduce the roundtrip if when creating a PR every
> contributor is reminded of
> * Did you run prepare-commit.sh?
> * Have you written a unit test where applicable?
> * Did you create .sip bindings?
> * Did you write API documentation?
> * Is your commit message meaningful?
> * Did you add [needs-docs] or [feature] tags to the commit message and
> include enough information for documentors in the commit message?
> Is there more information that should be included?
> Would you mind setting up a draft for it?
> Matthias
> [1] https://github.com/qgis/QGIS/pull/2581
> On 02/19/2016 07:45 AM, Alexander Bruy wrote:
> > Hi all,
> > recently GitHub introduced templates support for issues and
> > pul-request, see [0, 1].
> > Maybe we can utilize this functionality in our repos. For example,
> > issue template
> > can be used for the QEP repository and PR templates for main QGIS repo as
> > well as for QGIS-Processing and maybe some other.
> > Opinions?
> > [0] https://github.com/blog/2111-issue-and-pull-request-templates
> > [1]
> https://help.github.com/articles/helping-people-contribute-to-your-project/
> Matthias Kuhn
> OPENGIS.ch - https://www.opengis.ch
> Spatial • (Q)GIS • PostGIS • Open Source
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Alexander Bruy
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160222/042a1a68/attachment.html>
