[Qgis-developer] A common set of functions for QGIS plugins
    Luigi Pirelli
    luipir at gmail.com
    Sat Feb 20 09:59:23 PST 2016
I agree... I discovered them casually browsing the code, and then I
browsed all stuff named Qgs...Widget
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 19 February 2016 at 13:28, Victor Olaya <volayaf at gmail.com> wrote:
> +1 to promote the custom widgets. I dont think that many plugin
> developers are aware of them, since there is no documentation about
> them AFAIK
> 2016-02-19 13:24 GMT+01:00 Neumann, Andreas <a.neumann at carto.net>:
>> Hi,
>> The upcoming user conference in Girona may be a good opportunity to present
>> and advertise about both the common set of Python functions, but also about
>> the standard and custom widgets.
>> The CfP is still running and they are looking for more submissions. Maybe
>> someone could do a presentation for Python plugin authors to make them
>> aware?
>> Andreas
>> On 2016-02-19 11:36, Denis Rouzaud wrote:
>> On 02/19/2016 11:29 AM, Nyall Dawson wrote:
>> On 19 Feb 2016 19:35, "Etienne Trimaille" <etienne.trimaille at gmail.com>
>> wrote:
>>> I'm discovering that 'old' topic.
>>> Yes, I really like the idea, but I wasn't aware about that.
>>> I think the UI should be more uniform between plugins and QGIS, for
>>> instance to have :
>>> - the same combobox about layers (using the symbol for the geometry type
>>> and the EPSG if the checkbox is checked in the Processing settings)
>>> - the same combobox for table fields (symbol with the kind of field :
>>> integer, char ...)
>>> - the same output field with the menu (save to temp file, save to vector
>>> file, save to ...) like in processing.
>> Just a little advice - we need to push people toward the standard widgets
>> for these, eg QgsFieldComboBox, QgsMapLayerComboBox. Reimplementing then
>> with new Python versions isn't a good idea, since it breaks consistency with
>> core (and is also a lot of extra work!)
>> I would say, we even need to advertise the custom widgets.
>> All these widgets are availble in Qt Designer, it's quite easy to use them
>> from there.
>> Nyall
>>> So I will try to use that and contribute to these wrappers if I can.
>>> By the way, is it possible to recommend on the pyqgis cookbook (or the
>>> qgis documentation) to use the processing framework more often ? A lot of
>>> plugins are useful but we can't use them in batch mode or in complex
>>> workflow. Moreover, they often produce only shapefile.
>>> There are some very nice settings in Processing like "use selected
>>> features", default output format for vector and raster ... I think plugins
>>> should try to more compliant with these settings.
>>> 2016-02-19 8:55 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
>>>> Il 19/02/2016 08:53, Victor Olaya ha scritto:
>>>> > I dont think it wil hurt to add it to the main repo. While we develop,
>>>> > and the methods are not used yet, it will be just a bunch of files
>>>> > with dead code, so it is not risky, and maybe it is easier to engage
>>>> > people that way
>>>> I'd vote for it.
>>>> Thanks, Victor.
>>>> Paolo Cavallini - www.faunalia.eu
>>>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
