[Qgis-developer] A common set of functions for QGIS plugins
Nyall Dawson nyall.dawson at gmail.com
Tue Feb 23 17:56:33 PST 2016
On 21 February 2016 at 04:59, Luigi Pirelli <luipir at gmail.com> wrote:
> I agree... I discovered them casually browsing the code, and then I
> browsed all stuff named Qgs...Widget
FYI - to try to address this in future I've added a new entry to the
changelog detailing all the new PyQGIS classes added in 2.14 with a
bit of description for each (and link to API docs). Hopefully this
gives some more exposure to any newly added widgets/classes/etc.
Nyall
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> On 19 February 2016 at 13:28, Victor Olaya <volayaf at gmail.com> wrote:
>> +1 to promote the custom widgets. I dont think that many plugin
>> developers are aware of them, since there is no documentation about
>> them AFAIK
>> 2016-02-19 13:24 GMT+01:00 Neumann, Andreas <a.neumann at carto.net>:
>>> Hi,
>>> The upcoming user conference in Girona may be a good opportunity to present
>>> and advertise about both the common set of Python functions, but also about
>>> the standard and custom widgets.
>>> The CfP is still running and they are looking for more submissions. Maybe
>>> someone could do a presentation for Python plugin authors to make them
>>> aware?
>>> Andreas
>>> On 2016-02-19 11:36, Denis Rouzaud wrote:
>>> On 02/19/2016 11:29 AM, Nyall Dawson wrote:
>>> On 19 Feb 2016 19:35, "Etienne Trimaille" <etienne.trimaille at gmail.com>
>>> wrote:
>>>> I'm discovering that 'old' topic.
>>>> Yes, I really like the idea, but I wasn't aware about that.
>>>> I think the UI should be more uniform between plugins and QGIS, for
>>>> instance to have :
>>>> - the same combobox about layers (using the symbol for the geometry type
>>>> and the EPSG if the checkbox is checked in the Processing settings)
>>>> - the same combobox for table fields (symbol with the kind of field :
>>>> integer, char ...)
>>>> - the same output field with the menu (save to temp file, save to vector
>>>> file, save to ...) like in processing.
>>> Just a little advice - we need to push people toward the standard widgets
>>> for these, eg QgsFieldComboBox, QgsMapLayerComboBox. Reimplementing then
>>> with new Python versions isn't a good idea, since it breaks consistency with
>>> core (and is also a lot of extra work!)
>>> I would say, we even need to advertise the custom widgets.
>>> All these widgets are availble in Qt Designer, it's quite easy to use them
>>> from there.
>>> Nyall
>>>> So I will try to use that and contribute to these wrappers if I can.
>>>> By the way, is it possible to recommend on the pyqgis cookbook (or the
>>>> qgis documentation) to use the processing framework more often ? A lot of
>>>> plugins are useful but we can't use them in batch mode or in complex
>>>> workflow. Moreover, they often produce only shapefile.
>>>> There are some very nice settings in Processing like "use selected
>>>> features", default output format for vector and raster ... I think plugins
>>>> should try to more compliant with these settings.
>>>> 2016-02-19 8:55 GMT+01:00 Paolo Cavallini <cavallini at faunalia.it>:
>>>>> Il 19/02/2016 08:53, Victor Olaya ha scritto:
>>>>> > I dont think it wil hurt to add it to the main repo. While we develop,
>>>>> > and the methods are not used yet, it will be just a bunch of files
>>>>> > with dead code, so it is not risky, and maybe it is easier to engage
>>>>> > people that way
>>>>> I'd vote for it.
>>>>> Thanks, Victor.
>>>>> Paolo Cavallini - www.faunalia.eu
>>>>> QGIS & PostGIS courses: http://www.faunalia.eu/training.html
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
