[Qgis-developer] Some issues from GRASS plugin
Paolo Cavallini cavallini at faunalia.it
Mon Feb 22 02:58:56 PST 2016
Il 22/02/2016 11:53, Radim Blazek ha scritto:
> The "Set current QGIS extent" button was disabled if canvas extent was
> not valid but it was not re-enabled when it became valid again. I have
> fixed that in 81a1f6.
Thanks, Radim.
>> * the panel is far too wide for old 1024px screens, and cannot be shrunk
> The "New mapset" dialog? Here it is resizable and the first time it is
> started with 528x523, the geometry is saved/restored then. Can you
> resize it? Which tab cannot be shrunken?
The toolbox.
>> * if a location is added to favourites, its content is no longer usable
>> as GRASS data (the GRASS database has to be added instead)
> Confirmed, fixed in847f1c0.
Thanks again.
>> * while deleting a raster from the browser I got a crash, but I'm
>> struggling reproducing it.
> Deleting a GRASS map itself should not harm, it launches g.remove.
> More probably it crashes when browser content is refreshed which is
> done in threads. However, the functions should be locked where race
> condition can happen and that would be probably happening in other
> situations. What about deleting raster layer which is added in canvas?
> Trace back would be helpful.
I'll try to provide it.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
