[Qgis-developer] Begging for some fixes before LTR release
DelazJ delazj at gmail.com
Tue Feb 23 09:45:23 PST 2016
Thanks Andrea.
But what do u mean by "contextual legend in canvas"?
2016-02-23 15:05 GMT+01:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I guess that activating the contectual legend in the canvas, also in
> the composer the not visible layers should disapperaing.
> Is this ok for your usage ?
> A.
> 2016-02-23 14:22 GMT+01:00 DelazJ <delazj at gmail.com>:
> > Hi developers,
> > At less than a week for the release of the second LTR version (QGIS
> 2.14),
> > I'd like to draw your attention on two main issues that are not set as
> > blockers but I'd beg you to solve them:
> > #13575 (http://hub.qgis.org/issues/13575): adds all the available
> layers to
> > the legend in print composer instead of just adding those that are
> visible
> > in the map canvas. Not set as blocker (it should imho) but AFAICT this
> > behaviour was introduced in LTR 2.8 and it's not optimal at all when you
> > have a very big project.
> > #13418 (http://hub.qgis.org/issues/13418): it makes preset visibility
> pretty
> > unusable with print composers in (large) project with multiple print
> > composers. For any change you do to a preset, you need to manually echo
> it
> > in the map composer properties if you want your maps to be up to date.
> It's
> > just unmanageable in, once again, big project (since 2.10 if I'm not
> wrong).
> > I know that there are currently some blocking issues, maybe more
> sensitive
> > but these ones just block me (and surely many other people) in my daily
> > work. I'd be grateful to you if someone can give a look to these issues.
> > Thanks for the fixes :) and thanks for the great work you're doing with
> > QGIS.
> > DelazJ
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Andrea Peri
> qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160223/d9e5ba26/attachment.html>
