[Qgis-developer] Begging for some fixes before LTR release
Rouzaud Denis
denis.rouzaud at gmail.com
Tue Feb 23 10:01:32 PST 2016
> On 23 Feb 2016, at 14:22, DelazJ <delazj at gmail.com> wrote:
> Hi developers,
> At less than a week for the release of the second LTR version (QGIS 2.14), I'd like to draw your attention on two main issues that are not set as blockers but I'd beg you to solve them:
> #13575 (http://hub.qgis.org/issues/13575 <http://hub.qgis.org/issues/13575>): adds all the available layers to the legend in print composer instead of just adding those that are visible in the map canvas. Not set as blocker (it should imho) but AFAICT this behaviour was introduced in LTR 2.8 and it's not optimal at all when you have a very big project.
> #13418 (http://hub.qgis.org/issues/13418 <http://hub.qgis.org/issues/13418>): it makes preset visibility pretty unusable with print composers in (large) project with multiple print composers. For any change you do to a preset, you need to manually echo it in the map composer properties if you want your maps to be up to date. It's just unmanageable in, once again, big project (since 2.10 if I'm not wrong).
+1 this is indeed very painful.
> I know that there are currently some blocking issues, maybe more sensitive but these ones just block me (and surely many other people) in my daily work. I'd be grateful to you if someone can give a look to these issues.
> Thanks for the fixes :) and thanks for the great work you're doing with QGIS.
> DelazJ
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160223/646b2115/attachment.html>
