[Qgis-developer] Expression variables in QGIS server
    Tom Palan
    thomas at palan.at
    Fri Feb 26 08:36:14 PST 2016
btw I'm using QGIS 2.12.3 compiled from github
On Fri, Feb 26, 2016 at 05:34:59PM +0100, Tom Palan wrote:
> hi,
> I was trying to implement dynamic setting of Expression Variables when handling server requests (Example use case: I want to render another logo in a composition map depending on a project-variable), as I got stuck testing the behaviour of expression variables in server-requests.
> I have a print composition map, where a label text is set to a project scope expression variable. When I execute the server request the label is not printed (or printed empty).
> Does QGIS server not use expression variables defined at project level?
> thanks,
> Tom Palan
> palan3 IT solutions OG
> Grillenbergstr. 4
> A-4407 Dietach
> Tel.: +43 (0) 680 3280940
Tom Palan
Grillenbergstr. 4
A-4407 Dietach
