[Qgis-developer] Expression variables in QGIS server
Tom Palan
thomas at palan.at
Fri Feb 26 08:34:59 PST 2016
hi,
I was trying to implement dynamic setting of Expression Variables when handling server requests (Example use case: I want to render another logo in a composition map depending on a project-variable), as I got stuck testing the behaviour of expression variables in server-requests.
I have a print composition map, where a label text is set to a project scope expression variable. When I execute the server request the label is not printed (or printed empty).
Does QGIS server not use expression variables defined at project level?
thanks,
Tom Palan
palan3 IT solutions OG
Grillenbergstr. 4
A-4407 Dietach
Tel.: +43 (0) 680 3280940
