[Qgis-developer] Compiling QGIS with GRASS Plugin
Tim Sutton
tim at qgis.org
Fri Feb 26 10:36:19 PST 2016
Hi
> On 26 Feb 2016, at 18:32, m roy <royroge at outlook.com> wrote:
> Hi,
> i'm learning to compile QGIS in Ubuntu 14.04,
> managed to compile QGIS 2.14 and installed
> in a custom dir with make install,
> with:
> export LD_LIBRARY_PATH
> QGIS starts (by the way the 2.14 splash screen image is HUGE :))
Already fixed, thanks for the mention though.
Regards
Tim
> with some warnings and one error:
> ERROR 4: `/initrd.img' not recognised as a supported file format.
> but it seems to work, anyway i cannot find the GRASS Plugin, is there
> some other variable to set so that QGIS can see it ?
> libgrass*7.so are present in the lib/qgis/plugins/ directory so i do not
> think there is a compile issue (?)
> thanks ! Roy.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
QGIS Project Steering Committee Member
tim at qgis.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160226/5920b4a7/attachment.html>
Type: image/tiff
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160226/5920b4a7/attachment.tiff>
