[Qgis-developer] Compiling QGIS with GRASS Plugin
J.O. Williams j.o.williams.jow at gmail.com
Fri Feb 26 09:21:39 PST 2016
Sirs:
The /initrd.img probably should be specifically excluded from any scan
list.  It is a "ln -s" link to the real file on my Ubuntu system
"/boot/initrd.img-4.2.0-30-generic" which as I recall, is the temporary
file system that is loaded when the kernel first boots. Parts of the
file are released (freed) when they are no longer needed.
If you copy this file "initrd.img-4.2.0-30-generic" to a temp location
and add the .gz suffix, it can be gunzip into the equivalent of an
.iso.  Use a file manager to temporarily mount it. The iso contents look
like a Linux file system.
Regards,
J.O. Williams
On 02/26/2016 09:48 AM, m roy wrote:
> Ciao Marco,
> is it mandatory to use ccmake? because i compiled with "regular"
> cmake, make, make install ...
> Il 26/02/2016 17:44, Marco Bernasocchi ha scritto:
>> In ccmake there with_grass iirc
>> Ciao
>> On 26 February 2016 17:32:37 CET, m roy <royroge at outlook.com> wrote:
>>     Hi,
>>     i'm learning to compile QGIS in Ubuntu 14.04,
>>     managed to compile QGIS 2.14 and installed
>>     in a custom dir with make install,
>>     with:
>>     export LD_LIBRARY_PATH
>>     QGIS starts (by the way the 2.14 splash screen image is HUGE :))
>>     with some warnings and one error:
>>     ERROR 4: `/initrd.img' not recognised as a supported file format.
>>     but it seems to work, anyway i cannot find the GRASS Plugin, is there
>>     some other variable to set so that QGIS can see it ?
>>     libgrass*7.so <http://7.so>  are present in the lib/qgis/plugins/ directory so i do not
>>     think there is a compile issue (?)
>>     thanks ! Roy.
>>     Qgis-developer mailing list
>>     Qgis-developer at lists.osgeo.org
>>     List info:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>     Unsubscribe:http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> -- Marco Bernasocchi (mobile). OPENGIS.ch <http://OPENGIS.ch> -
>> berna.io <http://berna.io> - 27summits.ch <http://27summits.ch>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160226/4f10e483/attachment-0001.html>
