[Qgis-developer] Compiling QGIS with GRASS Plugin
    m roy
    royroge at outlook.com
    Mon Feb 29 01:49:06 PST 2016
Radim, thank you so much it worked!
Il 29/02/2016 09:21, Radim Blazek ha scritto:
> If the lib, provider and plugin are really compiled
> (lib/libqgisgrass7.so, lib/qgis/plugins/libgrassprovider7.so,
> libgrassrasterprovider7.so, libgrassplugin7.so) try to add path to
> GRASS libs dir (containing libgrass_gis.so etc.) to LD_LIBRARY_PATH.
> If it is already there or it does not help, find why it fails in "Log
> Messages Panel > Plugins". It should print something like: "Failed to
> load libgrassprovider7.so (Reason: Cannot load library
> libgrassprovider7.so: (libgrass_vector.so: cannot open shared object
> file: No such file or directory))" Radim
