[Qgis-developer] Compiling QGIS with GRASS Plugin
m roy
royroge at outlook.com
Fri Feb 26 08:48:05 PST 2016
Ciao Marco,
is it mandatory to use ccmake? because i compiled with "regular"
cmake, make, make install ...
Il 26/02/2016 17:44, Marco Bernasocchi ha scritto:
In ccmake there with_grass iirc
Ciao
On 26 February 2016 17:32:37 CET, m roy <royroge at outlook.com><mailto:royroge at outlook.com> wrote:
i'm learning to compile QGIS in Ubuntu 14.04,
managed to compile QGIS 2.14 and installed
in a custom dir with make install,
with:
export LD_LIBRARY_PATH
QGIS starts (by the way the 2.14 splash screen image is HUGE :))
with some warnings and one error:
ERROR 4: `/initrd.img' not recognised as a supported file format.
but it seems to work, anyway i cannot find the GRASS Plugin, is there
some other variable to set so that QGIS can see it ?
libgrass*7.so<http://7.so> are present in the lib/qgis/plugins/ directory so i do not
think there is a compile issue (?)
thanks ! Roy.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
-- Marco Bernasocchi (mobile). OPENGIS.ch<http://OPENGIS.ch> - berna.io<http://berna.io> - 27summits.ch<http://27summits.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160226/e508a253/attachment.html>
