[Qgis-developer] 2.5d - a couple of suggestions
Nyall Dawson
nyall.dawson at gmail.com
Fri Feb 26 10:59:24 PST 2016
On 26 Feb 2016 23:19, "Matthias Kuhn" <matthias at opengis.ch> wrote:
> > 2. Rotating the map rotates the 2.5d render. To me, that's not
expected, and
> > the render should be reapplied after the map rotation has taken place.
> That would require the map rotation to be available as expression
> variable (not sure if it is). Compensating for it with this variable
> shouldn't be hard.
It is, from memory it's @map_rotation.
Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160227/81a27fdb/attachment.html>
