[Qgis-developer] 2.5d - a couple of suggestions
Luca Mandolesi mandoluca at gmail.com
Sat Feb 27 02:41:42 PST 2016
Sorry for the question.
I follow the video on vimeo, but the extrusion doesn't work properly. It's
extruded only a vertex of the whole polygon.
It's a temporary bug, I must to open a ticket?
I'm working on windows 7, Osgeo setup.
2016-02-26 19:59 GMT+01:00 Nyall Dawson <nyall.dawson at gmail.com>:
> On 26 Feb 2016 23:19, "Matthias Kuhn" <matthias at opengis.ch> wrote:
> > > 2. Rotating the map rotates the 2.5d render. To me, that's not
> expected, and
> > > the render should be reapplied after the map rotation has taken place.
> > That would require the map rotation to be available as expression
> > variable (not sure if it is). Compensating for it with this variable
> > shouldn't be hard.
> It is, from memory it's @map_rotation.
> Nyall
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160227/254da838/attachment.html>
