[Qgis-developer] Compiling QGIS with GRASS Plugin
m roy
royroge at outlook.com
Sat Feb 27 00:09:46 PST 2016
I recompiled QGIS using ccmake but the problem remains,
QGIS starts but fails to recognize GRASS Plugin which is
not available in the installed plugins list ...
any other idea?
Il 26/02/2016 18:01, Marco Bernasocchi ha scritto:
Nope just pass -DWITH_GRASS=ON to cmake.
Ccmake is a great way to see what switches you can use.
Ciao
On 26 February 2016 17:48:05 CET, m roy <royroge at outlook.com><mailto:royroge at outlook.com> wrote:
Ciao Marco,
is it mandatory to use ccmake? because i compiled with "regular"
cmake, make, make install ...
Il 26/02/2016 17:44, Marco Bernasocchi ha scritto:
In ccmake there with_grass iirc
Ciao
On 26 February 2016 17:32:37 CET, m roy <royroge at outlook.com><mailto:royroge at outlook.com> wrote:
i'm learning to compile QGIS in Ubuntu 14.04,
managed to compile QGIS 2.14 and installed
in a custom dir with make install,
with:
export LD_LIBRARY_PATH
QGIS starts (by the way the 2.14 splash screen image is HUGE :))
with some warnings and one error:
ERROR 4: `/initrd.img' not recognised as a supported file format.
but it seems to work, anyway i cannot find the GRASS Plugin, is there
some other variable to set so that QGIS can see it ?
libgrass*7.so<http://7.so> are present in the lib/qgis/plugins/ directory so i do not
think there is a compile issue (?)
thanks ! Roy.
Qgis-developer mailing list
Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
-- Marco Bernasocchi (mobile). OPENGIS.ch<http://OPENGIS.ch> - berna.io<http://berna.io> - 27summits.ch<http://27summits.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160227/2192673b/attachment.html>
