[Qgis-developer] Compiling QGIS with GRASS Plugin
Sachin Chowdhary
chowdhary.sachin at gmail.com
Sat Feb 27 01:25:25 PST 2016
Hi all
I had compiled Qgis 2.8.4 successfully. Can any body tell me how to make
installer exe of it to install on Windows. I had used msvs2010 for build.
Regards
Sachin
On 27-Feb-2016 1:39 PM, "m roy" <royroge at outlook.com> wrote:
> I recompiled QGIS using ccmake but the problem remains,
> QGIS starts but fails to recognize GRASS Plugin which is
> not available in the installed plugins list ...
> any other idea?
> Il 26/02/2016 18:01, Marco Bernasocchi ha scritto:
> Nope just pass -DWITH_GRASS=ON to cmake.
> Ccmake is a great way to see what switches you can use.
> Ciao
> On 26 February 2016 17:48:05 CET, m roy <royroge at outlook.com>
>> Ciao Marco,
>> is it mandatory to use ccmake? because i compiled with "regular"
>> cmake, make, make install ...
>> Il 26/02/2016 17:44, Marco Bernasocchi ha scritto:
>> In ccmake there with_grass iirc
>> Ciao
>> On 26 February 2016 17:32:37 CET, m roy <royroge at outlook.com>
>>> Hi,
>>> i'm learning to compile QGIS in Ubuntu 14.04,
>>> managed to compile QGIS 2.14 and installed
>>> in a custom dir with make install,
>>> with:
>>> export LD_LIBRARY_PATH
>>> QGIS starts (by the way the 2.14 splash screen image is HUGE :))
>>> with some warnings and one error:
>>> ERROR 4: `/initrd.img' not recognised as a supported file format.
>>> but it seems to work, anyway i cannot find the GRASS Plugin, is there
>>> some other variable to set so that QGIS can see it ?
>>> libgrass*7.so are present in the lib/qgis/plugins/ directory so i do not
>>> think there is a compile issue (?)
>>> thanks ! Roy.
>>> Qgis-developer mailing listQgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> -- Marco Bernasocchi (mobile). OPENGIS.ch - berna.io - 27summits.ch
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160227/23a6baf0/attachment.html>
