[Qgis-developer] QGIS deb uninstallable?
Paolo Cavallini
cavallini at faunalia.it
Tue Jan 5 02:54:17 PST 2016
Il 05/01/2016 11:52, Paolo Cavallini ha scritto:
> However, now installing the build deps results in an error:
Better:
apt-get install libgsl0-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libgsl0-dev : Depends: libgsl0ldbl (= 1.16+dfsg-4) but it is not going
to be installed
E: Unable to correct problems, you have held broken packages.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
