[Qgis-developer] Working on Postgres provider PKI authentication support
Luigi Pirelli
luipir at gmail.com
Mon Jan 11 10:43:20 PST 2016
Hi SebDieBln (I've no your email)
I'm working for Boundless to add PKI authentication to postgres
provider. I see you did some work on it:
https://github.com/qgis/QGIS/pull/2473
This email is to share some instruments I did to allow a environmental
testing. I hope are useful for you and for all the community.
I'm developing qgis patches here (<- sorry SebDieBln ;) )
https://github.com/luipir/qgis/tree/postgis-pki
To allow a better testing env (integration test not unit test) I
prepared some docker data containers on the top of tim's
kartoza/postgis docker.
These containers allow to run a postgis container configured to accept
certified connections using test certs in:
https://github.com/qgis/QGIS/tree/master/tests/testdata/auth_system/certs_keys
You can find this containers here (sorry again ;) )
https://github.com/luipir/Postgis-pki-datacontainers
eventually you can use this container to setup a certified connection
for you db manager patches.
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
