[Qgis-developer] Working on Postgres provider PKI authentication support
Matthias Kuhn matthias at opengis.ch
Mon Jan 11 10:58:16 PST 2016
Hi Luigi,
Would it make sense to start such a container on travis and run some
checks against it from the test suite?
This would allow for a very quick feedback if somebody cuts the wrong wire.
Best regards,
Matthias
On 01/11/2016 07:43 PM, Luigi Pirelli wrote:
> Hi SebDieBln (I've no your email)
> I'm working for Boundless to add PKI authentication to postgres
> provider. I see you did some work on it:
> https://github.com/qgis/QGIS/pull/2473
> This email is to share some instruments I did to allow a environmental
> testing. I hope are useful for you and for all the community.
> I'm developing qgis patches here (<- sorry SebDieBln ;) )
> https://github.com/luipir/qgis/tree/postgis-pki
> To allow a better testing env (integration test not unit test) I
> prepared some docker data containers on the top of tim's
> kartoza/postgis docker.
> These containers allow to run a postgis container configured to accept
> certified connections using test certs in:
> https://github.com/qgis/QGIS/tree/master/tests/testdata/auth_system/certs_keys
> You can find this containers here (sorry again ;) )
> https://github.com/luipir/Postgis-pki-datacontainers
> eventually you can use this container to setup a certified connection
> for you db manager patches.
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS:
> https://www.packtpub.com/application-development/mastering-qgis
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160111/0ae23160/attachment.sig>
