[Qgis-developer] Geometry modifiers for labeling
Andreas Neumann a.neumann at carto.net
Wed Jan 13 05:59:08 PST 2016
Hi Matthias,
You can just add several rules that all apply at the same time (e.g. two
times an empty rule only bound by map scale ranges).
In the placement options use one time "above line", and the other time "
below line".
This works fine. See screenshot at
http://www.carto.net/neumann/temp/label_multiple_times.png
The workaround with font-markers from Matthieu works fine, but it is
ugly that the labels can be up-side-down.
Andreas
On 13.01.2016 14:45, Matthias Kuhn wrote:
> Hi Andreas
> On 01/13/2016 01:59 PM, Andreas Neumann wrote:
>> Hi Matthias,
>> Yes - with the new rule-based renderer we can label a line several times
>> - e.g. have one label above the line and another with another label text
>> below the line.
> I can't find the possibility to label the same feature twice, only
> different labeling rules for different features.
> But I guess you can use "data defined placement" instead of "above" or
> "below"?
> Matthias
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
