[Qgis-developer] Geometry modifiers for labeling
Matthias Kuhn
matthias at opengis.ch
Wed Jan 13 06:01:58 PST 2016
Good to know.
So that should work find with my previous recommendation of using
"Placement" -> "Data Defined"?
On 01/13/2016 02:59 PM, Andreas Neumann wrote:
> Hi Matthias,
> You can just add several rules that all apply at the same time (e.g.
> two times an empty rule only bound by map scale ranges).
> In the placement options use one time "above line", and the other time
> " below line".
> This works fine. See screenshot at
> http://www.carto.net/neumann/temp/label_multiple_times.png
> The workaround with font-markers from Matthieu works fine, but it is
> ugly that the labels can be up-side-down.
> Andreas
> On 13.01.2016 14:45, Matthias Kuhn wrote:
>> Hi Andreas
>> On 01/13/2016 01:59 PM, Andreas Neumann wrote:
>>> Hi Matthias,
>>> Yes - with the new rule-based renderer we can label a line several
>>> times
>>> - e.g. have one label above the line and another with another label
>>> text
>>> below the line.
>> I can't find the possibility to label the same feature twice, only
>> different labeling rules for different features.
>> But I guess you can use "data defined placement" instead of "above" or
>> "below"?
>> Matthias
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
OPENGIS.ch - https://www.opengis.ch
Spatial • (Q)GIS • PostGIS • Open Source
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160113/e20bbae3/attachment-0001.sig>
