[Qgis-developer] Error inserting new feature in geoserver wfs-t layer
Calzavara Antonio antonio.calzavara at provincia.padova.it
Thu Jan 14 00:28:53 PST 2016
We have a multipolygon layer in postgis exposed as wfs-t layer in geoserver.
We are trying to edit it with QGis 2.12.1, and we can update and delete feature, but we have some problems inserting new feature
If we create a feature with a single polygon, on saving we always have an error:
Could not commit changes to layer piove_di_sacco:d3cp_fabbricati
Errors: ERROR: 1 feature(s) not added.
Provider errors:
unsuccessful service response: Error performing insert: java.lang.String cannot be cast to com.vividsolutions.jts.geom.Geometry
But if we create two polygon and merge them as a single feature, then insert works.
It seems QGis send a gml multypoligon feature if there is more than a polygon, a polygon feature otherwise, while geoserver needs a strictly corresponding feature type with that defined on the layer.
I think the correct behavior was to create a multypoligon feature with a single ring if the wfs layer is a multipolygon.
Is there a workaround? Force QGis to always send multypoligon feature type?
We have the same behavior with a multilinestring layer inserting single linestring.
Thanks
Antonio Calzavara
U.O. Sistema Informativo Territoriale
Settore Sistemi Informativi
Provincia di Padova
Piazza Antenore, 3 - 35121 PADOVA
*tel: 0498201313 - 6fax: 0498201303
*email: antonio.calzavara at provincia.padova.it<mailto:antonio.calzavara at provincia.padova.it>
Skype:  tony.kaltz
Questo messaggio potrebbe contenere opinioni personali le quali non costituiscono impegni o posizioni ufficiali, salvo sia diversamente indicato. Il presente messaggio, corredato degli eventuali relativi allegati, contiene informazioni da considerarsi strettamente riservate ai sensi della vigente normativa in materia di protezione dei dati personali, ed e' destinato esclusivamente al/ai destinatario/i sopra indicato/i.
"Nota di riservatezza (D.lgs 196/03) - Chiunque ricevesse questo messaggio erroneamente, o comunque lo leggesse senza esserne legittimato, e' informato che trattenerlo, copiarlo, divulgarlo, distribuirlo a persone diverse dal destinatario e' severamente vietato, ed e' pregato di rinviarlo immediatamente al mittente distruggendone l'originale. Grazie."
Questa mail e' stata assoggettata a monitoraggio antivirus. Parte del contenuto e/o degli allegati potrebbero essere stati memorizzati e la loro gestione avviene in coformita' a quanto previsto dal D.lgs 196/03 e successive modifiche.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160114/5976fb49/attachment-0001.html>
