[Qgis-developer] Working on Postgres provider PKI authentication support
Luigi Pirelli luipir at gmail.com
Thu Jan 14 05:57:26 PST 2016
I just did PR for this new feature integrating the work of SebDieBln
https://github.com/qgis/QGIS/pull/2674
I just realised that my PKI postgis dockers misses some permission (I
pushed my repo... but cloning, key files have permission changed)...
I'll fix soon.
cheers
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 11 January 2016 at 20:08, Luigi Pirelli <luipir at gmail.com> wrote:
> I shared it also for this reason
> I hope is well configured for the travis context... it's open to have
> only ssl cert connection from every host.
> It works till verify-ca but not vefiry-full because test server cert
> is locked to "localhost" commonName only and docker instance use a
> different ip.
> enjoy these dockers and thanks to Time to share first ssl enabled
> postgis docker.
> Luigi Pirelli
> * Mastering QGIS:
> On 11 January 2016 at 19:58, Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi Luigi,
>> Would it make sense to start such a container on travis and run some
>> checks against it from the test suite?
>> This would allow for a very quick feedback if somebody cuts the wrong wire.
>> Best regards,
>> Matthias
>> On 01/11/2016 07:43 PM, Luigi Pirelli wrote:
>>> Hi SebDieBln (I've no your email)
>>> I'm working for Boundless to add PKI authentication to postgres
>>> provider. I see you did some work on it:
>>> https://github.com/qgis/QGIS/pull/2473
>>> This email is to share some instruments I did to allow a environmental
>>> testing. I hope are useful for you and for all the community.
>>> I'm developing qgis patches here (<- sorry SebDieBln ;) )
>>> https://github.com/luipir/qgis/tree/postgis-pki
>>> To allow a better testing env (integration test not unit test) I
>>> prepared some docker data containers on the top of tim's
>>> kartoza/postgis docker.
>>> These containers allow to run a postgis container configured to accept
>>> certified connections using test certs in:
>>> https://github.com/qgis/QGIS/tree/master/tests/testdata/auth_system/certs_keys
>>> You can find this containers here (sorry again ;) )
>>> https://github.com/luipir/Postgis-pki-datacontainers
>>> eventually you can use this container to setup a certified connection
>>> for you db manager patches.
>>> Luigi Pirelli
>>> * Mastering QGIS:
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Matthias Kuhn
>> OPENGIS.ch - https://www.opengis.ch
>> Spatial • (Q)GIS • PostGIS • Open Source
