[Qgis-developer] Working on Postgres provider PKI authentication support
Luigi Pirelli
luipir at gmail.com
Sun Jan 17 13:13:42 PST 2016
....And I fixed the problems of the Postgis PKI enabled dockers data
containers...
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS:
https://www.packtpub.com/application-development/mastering-qgis
On 14 January 2016 at 14:57, Luigi Pirelli <luipir at gmail.com> wrote:
> I just did PR for this new feature integrating the work of SebDieBln
> https://github.com/qgis/QGIS/pull/2674
> I just realised that my PKI postgis dockers misses some permission (I
> pushed my repo... but cloning, key files have permission changed)...
> I'll fix soon.
> cheers
> Luigi Pirelli
> * Mastering QGIS:
> On 11 January 2016 at 20:08, Luigi Pirelli <luipir at gmail.com> wrote:
>> I shared it also for this reason
>> I hope is well configured for the travis context... it's open to have
>> only ssl cert connection from every host.
>> It works till verify-ca but not vefiry-full because test server cert
>> is locked to "localhost" commonName only and docker instance use a
>> different ip.
>> enjoy these dockers and thanks to Time to share first ssl enabled
>> postgis docker.
>> Luigi Pirelli
>> * Mastering QGIS:
>> On 11 January 2016 at 19:58, Matthias Kuhn <matthias at opengis.ch> wrote:
>>> Hi Luigi,
>>> Would it make sense to start such a container on travis and run some
>>> checks against it from the test suite?
>>> This would allow for a very quick feedback if somebody cuts the wrong wire.
>>> Best regards,
>>> Matthias
>>> On 01/11/2016 07:43 PM, Luigi Pirelli wrote:
>>>> Hi SebDieBln (I've no your email)
>>>> I'm working for Boundless to add PKI authentication to postgres
>>>> provider. I see you did some work on it:
>>>> https://github.com/qgis/QGIS/pull/2473
>>>> This email is to share some instruments I did to allow a environmental
>>>> testing. I hope are useful for you and for all the community.
>>>> I'm developing qgis patches here (<- sorry SebDieBln ;) )
>>>> https://github.com/luipir/qgis/tree/postgis-pki
>>>> To allow a better testing env (integration test not unit test) I
>>>> prepared some docker data containers on the top of tim's
>>>> kartoza/postgis docker.
>>>> These containers allow to run a postgis container configured to accept
>>>> certified connections using test certs in:
>>>> https://github.com/qgis/QGIS/tree/master/tests/testdata/auth_system/certs_keys
>>>> You can find this containers here (sorry again ;) )
>>>> https://github.com/luipir/Postgis-pki-datacontainers
>>>> eventually you can use this container to setup a certified connection
>>>> for you db manager patches.
>>>> Luigi Pirelli
>>>> * Mastering QGIS:
>>>> _______________________________________________
>>>> Qgis-developer mailing list
>>>> Qgis-developer at lists.osgeo.org
>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Matthias Kuhn
>>> OPENGIS.ch - https://www.opengis.ch
>>> Spatial • (Q)GIS • PostGIS • Open Source
