[Qgis-developer] Check geometry not fixing errors?
Sandro Mani manisandro at gmail.com
Fri Jan 15 08:45:51 PST 2016
On 15.01.2016 17:39, Paolo Cavallini wrote:
> Il 15/01/2016 17:34, Sandro Mani ha scritto:
>> Can you describe the steps to reproduce the case where a geometry ends
>> up getting thrown away?
> this happens quite reliably when using the lwgeom plugin and v.clean,
> both through Processing.
> thanks.
Okay, but did you encounter such issues with the geometry checker plugin
specifically? I did a couple of random tests and things seem to work
(except the layer creation issue mentioned previously).
Thanks
Sandro
