[Qgis-developer] Check geometry not fixing errors?
Paolo Cavallini cavallini at faunalia.it
Fri Jan 15 08:48:39 PST 2016
Il 15/01/2016 17:45, Sandro Mani ha scritto:
> Okay, but did you encounter such issues with the geometry checker plugin
> specifically? I did a couple of random tests and things seem to work
> (except the layer creation issue mentioned previously).
they were not dropped, but I ended up with a layer with more or less the
same errors as in the origin. I may be missing some options though.
If you want we can try debugging it from IRC.
Thanks.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
