[Qgis-developer] Check geometry not fixing errors?
Sandro Mani
manisandro at gmail.com
Fri Jan 15 08:53:57 PST 2016
On 15.01.2016 17:48, Paolo Cavallini wrote:
> Il 15/01/2016 17:45, Sandro Mani ha scritto:
>> Okay, but did you encounter such issues with the geometry checker plugin
>> specifically? I did a couple of random tests and things seem to work
>> (except the layer creation issue mentioned previously).
> they were not dropped, but I ended up with a layer with more or less the
> same errors as in the origin. I may be missing some options though.
> If you want we can try debugging it from IRC.
> Thanks.
About to leave right now, but if you can just list which layer and which
checks you picked I should be able to reproduce any issues easily.
Thanks
Sandro
