[Qgis-developer] Check geometry not fixing errors?
Paolo Cavallini
cavallini at faunalia.it
Fri Jan 22 01:06:59 PST 2016
Il 22/01/2016 10:02, Even Rouault ha scritto:
> Sounds like a PolygonZ (=1003) is passed to OGR as WKB encoded with ISO SQL/MM
> to GDAL 1.11 or older. Only GDAL 2.0 will support that. GDAL 1.X will only
> support old-style 99-402 extended dimension (Z) WKB, so Polygon25D =
> 0x80000003
Thanks Even. In this case, the plugin would be essentially broken in all
systems with gdal<2 (as in Debian sid9), right?
I'm using current master from debs.
All the best.
Paolo Cavallini - www.faunalia.eu
QGIS & PostGIS courses: http://www.faunalia.eu/training.html
