[Qgis-developer] GeoJSON issue
Etienne Trimaille etienne.trimaille at gmail.com
Sat Jan 23 04:44:59 PST 2016
For your information Enrico, there are these tickets about the problem :
http://hub.qgis.org/issues/11587
http://hub.qgis.org/issues/12555
2016-01-23 12:58 GMT+01:00 kimaidou <kimaidou at gmail.com>:
> Hi,
> This is a known issue, in relation with decimal separator which depends on
> your local.
> See https://github.com/3liz/QuickOSM/issues/34
> Quick tip : run QGIS through terminal with following command
> LC_NUMERIC="C" /usr/bin/qgis 1> /dev/null 2> /dev/null
> 2016-01-23 11:47 GMT+01:00 Enrico Ferreguti <enricofer at gmail.com>:
>> I'm having a weird issue loading geojson on Qgis 2.12.3 under Ubuntu
>> 14.04 LTS
>> Features are loaded with coordinates truncated as if they were integer
>> number. It's a big problem with WGS84 projection because a point like
>> E11.3455668 N45.4566996 is inserted as E11 N45
>> The issue appears even loading geojson from URL so it can be easily
>> reproduced:
>> For example inserting GeoJSON from with:
>> http://api.mapillary.com/v1/im/search?min-lat=45.4236627857&max-lat=45.4276518411&min-lon=11.8448906543&max-lon=11.8637224647&max-results=200&geojson=true
>> all features collapsed to E11 N45
>> The problem does not reside on source because coordinates in the provided
>> GeJSON are right.
>> The strange is that other testing systems do not appear affected ( qgis
>> 2.12.2 under windows 32bit and qgis 2.10 under LUbuntu 14.04 LTS).
>> Is there Anyone who confims the issue? Should I open a ticket?
>> Regards.
>> Enrico Ferreguti
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160123/d695d572/attachment.html>
