[Qgis-developer] GeoJSON issue
kimaidou
kimaidou at gmail.com
Sat Jan 23 03:58:34 PST 2016
This is a known issue, in relation with decimal separator which depends on
your local.
See https://github.com/3liz/QuickOSM/issues/34
Quick tip : run QGIS through terminal with following command
LC_NUMERIC="C" /usr/bin/qgis 1> /dev/null 2> /dev/null
2016-01-23 11:47 GMT+01:00 Enrico Ferreguti <enricofer at gmail.com>:
> I'm having a weird issue loading geojson on Qgis 2.12.3 under Ubuntu 14.04
> LTS
> Features are loaded with coordinates truncated as if they were integer
> number. It's a big problem with WGS84 projection because a point like
> E11.3455668 N45.4566996 is inserted as E11 N45
> The issue appears even loading geojson from URL so it can be easily
> reproduced:
> For example inserting GeoJSON from with:
> http://api.mapillary.com/v1/im/search?min-lat=45.4236627857&max-lat=45.4276518411&min-lon=11.8448906543&max-lon=11.8637224647&max-results=200&geojson=true
> all features collapsed to E11 N45
> The problem does not reside on source because coordinates in the provided
> GeJSON are right.
> The strange is that other testing systems do not appear affected ( qgis
> 2.12.2 under windows 32bit and qgis 2.10 under LUbuntu 14.04 LTS).
> Is there Anyone who confims the issue? Should I open a ticket?
> Regards.
> Enrico Ferreguti
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160123/1702f4f6/attachment.html>
