[Qgis-developer] Processing provider versions and hard coded path in settings
Alexander Bruy
alexander.bruy at gmail.com
Mon Jan 25 04:18:29 PST 2016
Hi Stefan,
QGIS.ini is a place where QGIS (and Processing, because it is a core plugin)
stores iits settings. if ypu want to have different settings for different QGIS
versions just use --configpath command line option to define different places
to store settings.
Hope this helps
2016-01-25 13:54 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
> Hi Alex,
> Thanks for your reply, and sorry if my question was a bit unclear...
> When I want to use e.g. GRASS 7 in Processing, I have to provide the path to the "GRASS7 folder" in Processing --> Processing Options --> Providers
> From there, in my case e.g. "C:\Program Files (x86)\QGIS Lyon\apps\grass\grass-7.0.3RC2" has been saved as an absolute path to my QGIS.ini file in my home directory.
> If I use different QGIS versions in parallel (e.g. latest stable and LTR) the path can change. Furthermore, I have to update it manually, after each update of GRASS or SAGA (because then the paths change as well...
> This is what I meant, not the source code...
> But maybe it would be better to have the paths themselves more stable...
> Recently, Helmut Kudrnovsky did some work on making RStudio available in the GRASS console in OSGeo4W. Maybe something like this is needed to grab the path to GRASS, SAGA or R for processing...?
> Cheers
> Stefan
> -----Original Message-----
> From: Alexander Bruy [mailto:alexander.bruy at gmail.com]
> Sent: 25. januar 2016 12:13
> To: Blumentrath, Stefan <Stefan.Blumentrath at nina.no>
> Cc: qgis-developer at lists.osgeo.org
> Subject: Re: [Qgis-developer] Processing provider versions and hard coded path in settings
> Hi Stefan,
> Processing providers are just plugins, so they installed in the global QGIS plugins directory. There is no hadrcoding in Processing sources related to the providers.
> 2016-01-25 12:04 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no>:
>> Dear devs,
>> In my QGIS.ini, the paths to the Processing providers are hard coded,
>> which means I have to manually adjust them after every software update
>> (Saga, GRASS, R).
>> Any chance to pass the updates to the user(s)`s QGIS settings (or make
>> QGIS recognizing the Processing providers installed together with
>> QGIS), or is this only a limitation of the --configpath solution?.
>> Should I extend:
>> http://hub.qgis.org/issues/12623
>> (as it seems related) or should I open a new ticket (in case this
>> wanted and feasible of course)...
>> Kind regards,
>> Stefan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexander Bruy
Alexander Bruy
