[Qgis-developer] Build failure following qt creator setup instructions
Matthias Kuhn
matthias at opengis.ch
Sun Jul 3 10:53:49 PDT 2016
On 07/03/2016 03:15 PM, Andrea Aime wrote:
> On Sun, Jul 3, 2016 at 2:37 PM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
> Hi Andrea,
> On 07/03/2016 02:18 PM, Andrea Aime wrote:
> > File "/home/aaime/devel/qgis/scripts/pyuic-wrapper.py", line 26, in
> > <module>
> > import qgis.PyQt.uic.pyuic
> > ImportError: No module named PyQt.uic.pyuic
> > Any clue as to why the build is failing?
> Do you have (an old version of) QGIS installed via package manager?
> Yes, QGis 2.8.6 Wien, as part of the standard packages of Mint.
> Are you suggesting to remove it? Was kind of hoping to have two
> versions side by side, one stable for day to day work, and one built fresh
> to test SLD generation changes.
I am not sure what causes the build failure, it's not the first time I
hear about it but I've never been able to properly trace it to its roots
(and it never happened for me).
In short: I'm trying to find the cause.
If you could remove the qgis-python package from the system and check
back if the build failure persists that would help to assess the problem.
Matthias
