[Qgis-developer] Build failure following qt creator setup instructions
Andrea Aime
andrea.aime at geo-solutions.it
Sun Jul 3 13:18:28 PDT 2016
On Sun, Jul 3, 2016 at 7:53 PM, Matthias Kuhn <matthias at opengis.ch> wrote:
> > Yes, QGis 2.8.6 Wien, as part of the standard packages of Mint.
> > Are you suggesting to remove it? Was kind of hoping to have two
> > versions side by side, one stable for day to day work, and one built
> fresh
> > to test SLD generation changes.
> I am not sure what causes the build failure, it's not the first time I
> hear about it but I've never been able to properly trace it to its roots
> (and it never happened for me).
> In short: I'm trying to find the cause.
> If you could remove the qgis-python package from the system and check
> back if the build failure persists that would help to assess the problem.
Hey, I still haven't tried this but in the meantime the command line build
worked (after some fight with ccmake), I did not stumble into the
same error. So... well, I guess that gives me a way forward, but
I'll have a another look at the QT Creator build to see if the issue can be
traced, in order to add warnings/more directions into the dev guide.
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160703/25eb8cac/attachment.html>
