[Qgis-developer] FOSS4G code sprint idea: improving SLD export and GeoServer compatibility
Andrea Aime
andrea.aime at geo-solutions.it
Mon Jul 4 02:45:48 PDT 2016
On Mon, Jul 4, 2016 at 11:29 AM, Luigi Pirelli <luipir at gmail.com> wrote:
> data and project are here:
> https://github.com/faunalia/rt_mapserver_exporter/tree/2.0/test/data
Ah ha, thank you!
> I tried to implement a Qml2Sld converter using visitor patterns but I
> failed because qml is a mixture of hierarchic structure mixed with
> key/value flat organization with some interdependence among nodes...
> btw another reason can be related with my technical limitations :) )
> Btw I explored the test data above generating a couple of QMLs and
> (actual qgis generated) SLDs for each "atomic" symbol used in this set
> of test data.
> https://github.com/luipir/qml2sld-plugin/tree/master/qml2sld/tests/testdata/rt_mapserver_exporter
Yeah, I had the same idea some time ago, get a QGis project and add a
GeoServer Importer
plugin that would import the project fully, as a new workspace, including
data sources, layers,
and styles.
However that seemed a bit too large for a spare time project, and I am not
clear about what kind
of version to version compatibility rules there are for the project file
contents (e.g., how much
maintenance would one have to face in order to chase after QGis evolution
over the years).
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054 Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160704/48510e2d/attachment.html>
