[Qgis-developer] QGIS for INSPIRE
Hugo Mercier hugo.mercier at oslandia.com
Wed Jul 6 08:55:26 PDT 2016
Good to know you will start this work.
What do you mean by "Custom types widgets, per type" ?
For those interested, we've been working on a QGIS plugin to import
Complex Features XML in QGIS in a similar way (but using a pure python
approach to convert from XSD to a relational model).
See http://plugins.qgis.org/plugins/gml_application_schema_toolbox/
On 06/07/2016 16:27, Patrick Valsecchi wrote:
> Hi,
> We (titellus and camptocamp) are going to start working on adding a few
> functionalities needed for INSPIRE to QGIS core.  Before starting, we’d
> like to tell the community what we plan to do (maybe, some are optional)
> and give a chance to everybody to comment.
>     Advanced attribute types support
>       o
>         Add support for viewing/editing maps (key/value) and arrays
>             Usage of native type for postgis
>             Usage of string representation for sqlite (for example JSON)
>       o
>         Add a few expression functions for accessing those types:
>         array_get(idx), array_length, array_join(separator) /
>         dict_get(key), etc
>       o
>         Add a few function to search in those types: array_search(),
>         dict_search()
>       o
>         Detect a date column and use the proper widget for editing those
>       o
>         Same for other types
>       o
>         Allow plugins to provide custom widgets for specific types
>         automatically.
>     Fix bug where null dates are shown as the current time instead of
>     null in forms and saved like that, even for features that are not
>     modified
>     Auto discover database joins:
>       o
>         Add FK (Foreign Key) discovery to the postgis and spatialite
>         specific code.
>       o
>         Improve QGIS when creating relations according to the FK in the
>         DB: view existing relations in the DB and select those to add
>         automatically to the project.
>       o
>         Improve QGIS when creating joins in layers according to the FK
>         in the DB: view existing relations with the current layer and
>         select those to add automatically.
> If somebody is already working on one of those features or is having
> recommendations/comments/questions, please tell us.
> Is there any point that would require a QEP?
> Thanks
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
