[Qgis-developer] SLD export not compliant due to unit attribute in the root element
Alessandro Pasotti apasotti at gmail.com
Mon Jul 25 00:12:45 PDT 2016
On Sat, Jul 23, 2016 at 2:53 PM, Andrea Aime <andrea.aime at geo-solutions.it>
wrote:
> Hi,
> I'm looking into improving the SLD export, and stumbled into a schema
> violation
> that, if fixed, may cause other regression.
> In particular, the root element StyledLayerDescriptor contains a "units"
> attribute that
> is not part of the SLD/SE specification, and thus makes validation fail:
> <?xml version="1.0" encoding="UTF-8"?>
> <StyledLayerDescriptor xmlns="http://www.opengis.net/sld" xmlns:ogc="
> http://www.opengis.net/ogc" xmlns:xsi="
> http://www.w3.org/2001/XMLSchema-instance" version="1.1.0" xmlns:xlink="
> http://www.w3.org/1999/xlink" *units="mm" *xsi:schemaLocation="
> http://schemas.opengis.net/sld/1.1.0/StyledLayerDescriptor.xsd" xmlns:se="
> http://www.opengis.net/se">
> </StyledLayerDescriptor>
> It's in particular the units="mm" element. Checking the git history I
> found it has been introduced by this commit:
> b54b159 - rldhont <rldhont at gmail.com> 23-ott-2015
> [BUGFIX] Set default units to mm in exportSld
> The default units in QgsMapRenderer is Millimeters. The default units in
> SLD
>  is Pixel but exportSld does not convert all millimeters in pixels.
> We notes this bug by comparing default QGS Server rendering and rendering
> with
>  the SLD generated by QGIS.
> To resolve it, we just have to add units to the document element.
> The above comments seems to suggest something is actually using that
> attribute, but I'm not sure what.
> Mind, GeoServer can parse the file the same, but if users try to validate
> it (there is a validation button in the style editor), they will get the
> following error:
> "ine 2: cvc-complex-type.3.2.2: Attribute 'units' is not allowed to appear
> in element 'StyledLayerDescriptor'."
> Also, the attribute per se does nothing in a compliant client, since SLD
> 1.1 lacks the very concept of "on screen unit", the uom allowed
> are pixel (on screen), meter (on ground), feet (on ground).
> A SLD export trying to be compliant should convert mm to pixels assuming
> some DPI conversion factor (which means,
> making many changes around... bummer). I see there is already a uomScale
> in the conversion properties, but I see it's not
> used for point symbol sizes (as the commit message says.. I actually don't
> see it being used anywhere).
> Would it be ok to remove that attribute and use uomScale to properly adapt
> sizes from mm to px instead?
> Cheers
> Andrea
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Andrea Aime
> @geowolf
> Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A
> 55054  Massarosa (LU)
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39  339 8844549
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
I noticed the same 'uom' mm problem when I tested the SLD converting
routines used by GeoServer Explorer plugin a couple of months ago, thank
for bringing up this issue.
Your proposed solution makes perfectly sense to me.
Did you check if is there already an issue on hub.qgis.org?
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160725/e57fcab2/attachment.html>
