[Qgis-developer] Processing - R script parameters error
matteo matteo.ghetta at gmail.com
Tue Jul 26 01:25:43 PDT 2016
Hi all,
keeping on exploring the Processing - R script capabilities, there are
some input parameters that I'm not able to use.
For example there is the multiple field option, as described in the code:
In a script you can use it with
##Fields=[optional] multiple field [number|string] Parentinput
but if I use it in a script like
##layer=vector
##fields=multiple field layer
I get this error:
NameError
global name 'QtCore' is not defined
am I missing something?
Thanks
Matteo
