[Qgis-developer] How would I get the GRASS r.in.lidar and v.in.lidar programs to show up in the Processing Toolbox?
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Wed Jun 1 00:37:15 PDT 2016
Hi again,
I just saw that also the module descriptions are missing.
Try putting the attached file into:
YOUR_QGIS_INSTALLATION\apps\qgis\python\plugins\processing\algs\grass7\description
Maybe you have to remove the line containing
ParameterSelection|return_filter in the txt to make it run properly, as I do not know if it accepts an empty string as input... I did not test it...
In order to define the map extent you will have to inspect your las-file in advance (e.g. using las-tools).
Good luck.
Stefan
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Blumentrath, Stefan
Sent: 1. juni 2016 07:45
To: Jim Bellenger <bellengj at gmail.com>; Qgis-developer at lists.osgeo.org
Subject: Re: [Qgis-developer] How would I get the GRASS r.in.lidar and v.in.lidar programs to show up in the Processing Toolbox?
Hei Jim,
Without knowing some relevant details of your system I would guess you are facing this
https://trac.osgeo.org/osgeo4w/ticket/493
issue in liblas on Windows...
Cheers
Stefan
From: Qgis-developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Jim Bellenger
Sent: 1. juni 2016 05:01
To: Qgis-developer at lists.osgeo.org<mailto:Qgis-developer at lists.osgeo.org>
Subject: [Qgis-developer] How would I get the GRASS r.in.lidar and v.in.lidar programs to show up in the Processing Toolbox?
I know that the programs are installed with the GRASS 7.0.3 of QGIS 2.14 but they don't show up in the Processing Toolbox.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160601/316c34ef/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160601/316c34ef/attachment-0001.txt>
