[Qgis-developer] QGIS Layer Search Plugin
Jeremy Palmer JPalmer at linz.govt.nz
Mon Jun 6 22:16:27 PDT 2016
> I would personally prefer keeping it as a separate plugin, but what do you
> think? Should it be integrated with another plugin?
It seems like it has value over the other plugins. Another issue I’ve had is searching all layer fields and pushing the query filter down the provider (e.g PostGIS or WFS) to increase the performance and usability. Using the approach of iterating through all features client side with a large dataset can be a killer in terms of bandwidth, memory and time. Does your new plugin do that? If so then it would be really useful :)
This message contains information, which may be in confidence and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
