[Qgis-developer] QGIS Layer Search Plugin
kimaidou kimaidou at gmail.com
Tue Jun 7 06:27:33 PDT 2016
Hi all,
I think it is not really profitable to have multiple plugins. In my
opinion, efforts must be made to merge plugins when possible. In this case,
we have
* Quick Finder : Full Text Search is used here, which allows fuzzy search,
and is very efficient compared to scanning all features for a match. A
drawback, you must fill in the "FTS vectors" for each layer you want to be
able to search within. I think it is not so bad because the process is
fast. I also think there is nothing preventing to add more than one field
in the search ( it is possible with FTS in PostgreSQL, must also be the
case with sqlite)
* Layer search : Great to have a quick way to search among all the fields
of all loaded layers, with no configuration. Drawback : I think this can be
very slow for big datasets, and it is not "fuzzy", as regexp are used while
iterating on each feature. Another drawback : for external vector sources
like PostgreSQL, all features must been fetched !
IMHO, the way to go could be
* Add the FTS pregenerator of Quick Finder in Processing, as an alg
available for anyone to use
* Add the FTS search of Quick Finder as a Processing Alg
* Add the "layer search" worker as an Alg in Processing
* Have a combined plugin which let the user choose the search type : FTS
with pregeneration, or direct search with features iteration. This will
then run the corresponding alg
Cheers,
Michaël
2016-06-07 7:16 GMT+02:00 Jeremy Palmer <JPalmer at linz.govt.nz>:
> > I would personally prefer keeping it as a separate plugin, but what do
> you
> > think? Should it be integrated with another plugin?
> It seems like it has value over the other plugins. Another issue I’ve had
> is searching all layer fields and pushing the query filter down the
> provider (e.g PostGIS or WFS) to increase the performance and usability.
> Using the approach of iterating through all features client side with a
> large dataset can be a killer in terms of bandwidth, memory and time. Does
> your new plugin do that? If so then it would be really useful :)
> This message contains information, which may be in confidence and may be
> subject to legal privilege. If you are not the intended recipient, you must
> not peruse, use, disseminate, distribute or copy this message. If you have
> received this message in error, please notify us immediately (Phone 0800
> 665 463 or info at linz.govt.nz) and destroy the original message. LINZ
> accepts no responsibility for changes to this email, or for any
> attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160607/6a38f81d/attachment.html>
