[Qgis-developer] QGIS Layer Search Plugin
Denis Rouzaud denis.rouzaud at gmail.com
Tue Jun 7 23:20:43 PDT 2016
Dear all,
Indeed, the layer search offers something Quickfinder doesn't: searching
on all layers without any configuration, and the use of operators.
Although I think choosing an operator in a global search is not very
required (why doing price < 1000 on all layers, there is a pretty good
chance you know what layer you're looking for).
From this, I think Michael's idea is pretty good.
Make QuickFinder just a search bar in the application toolbar. Then you
can register any search process to it, which would be a processing alg:
might be OSM, FTS or Layer search.
I would definitely be ok to do so for QuickFinder.
But the question is when... It would take me a bit of time to reorganize
the plugin, make FTS generation and search as processing algs (never
done that before). I won't be able to achieve this before August.
So...is this fair to ask someone to wait that long for a dev and then
ask to modify its code to fit in? I have no answer, it's a real question.
Best wishes,
Denis
PS: yes, QuickFinder FTS search handles multiple columns as it supports
expressions (you can concatenate the columns).
On 06/07/2016 03:27 PM, kimaidou wrote:
> Hi all,
> I think it is not really profitable to have multiple plugins. In my
> opinion, efforts must be made to merge plugins when possible. In this
> case, we have
> * Quick Finder : Full Text Search is used here, which allows fuzzy
> search, and is very efficient compared to scanning all features for a
> match. A drawback, you must fill in the "FTS vectors" for each layer
> you want to be able to search within. I think it is not so bad because
> the process is fast. I also think there is nothing preventing to add
> more than one field in the search ( it is possible with FTS in
> PostgreSQL, must also be the case with sqlite)
> * Layer search : Great to have a quick way to search among all the
> fields of all loaded layers, with no configuration. Drawback : I think
> this can be very slow for big datasets, and it is not "fuzzy", as
> regexp are used while iterating on each feature. Another drawback :
> for external vector sources like PostgreSQL, all features must been
> fetched !
> IMHO, the way to go could be
> * Add the FTS pregenerator of Quick Finder in Processing, as an alg
> available for anyone to use
> * Add the FTS search of Quick Finder as a Processing Alg
> * Add the "layer search" worker as an Alg in Processing
> * Have a combined plugin which let the user choose the search type :
> FTS with pregeneration, or direct search with features iteration. This
> will then run the corresponding alg
> Cheers,
> Michaël
> 2016-06-07 7:16 GMT+02:00 Jeremy Palmer <JPalmer at linz.govt.nz
> <mailto:JPalmer at linz.govt.nz>>:
>     > I would personally prefer keeping it as a separate plugin, but
>     what do you
>     > think? Should it be integrated with another plugin?
>     It seems like it has value over the other plugins. Another issue
>     I’ve had is searching all layer fields and pushing the query
>     filter down the provider (e.g PostGIS or WFS) to increase the
>     performance and usability. Using the approach of iterating through
>     all features client side with a large dataset can be a killer in
>     terms of bandwidth, memory and time. Does your new plugin do that?
>     If so then it would be really useful :)
>     This message contains information, which may be in confidence and
>     may be subject to legal privilege. If you are not the intended
>     recipient, you must not peruse, use, disseminate, distribute or
>     copy this message. If you have received this message in error,
>     please notify us immediately (Phone 0800 665 463 or
>     info at linz.govt.nz <mailto:info at linz.govt.nz>) and destroy the
>     original message. LINZ accepts no responsibility for changes to
>     this email, or for any attachments, after its transmission from
>     LINZ. Thank You.
>     _______________________________________________
>     Qgis-developer mailing list
>     Qgis-developer at lists.osgeo.org <mailto:Qgis-developer at lists.osgeo.org>
>     List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160608/70e9f5cd/attachment.html>
