[Qgis-developer] Build issue on Ubuntu 16.04 xenial with release-2_14 : crssync target failed
Bas Couwenberg
sebastic at xs4all.nl
Wed Jun 8 02:53:10 PDT 2016
On 2016-06-08 11:46, kimaidou wrote:
> Here are the command lines used to make gdalinfo happy (quite hackish
> ln -s /usr/lib/x86_64-linux-gnu/libgif.so
> /usr/lib/x86_64-linux-gnu/libgif.so.4
> ln -s /usr/lib/x86_64-linux-gnu/libnetcdf.so
> /usr/lib/x86_64-linux-gnu/libnetcdf.so.7
> echo "/usr/lib/x86_64-linux-gnu/" >> /etc/ld.so.conf.d/qgis.conf
> ldconfig
Please don't ever create your own library symlinks, this is always
wrong.
You need to rebuild your GDAL with the currently installed dependencies,
as it looks like you upgraded the system packages but never rebuilt your
custom GDAL after you upgraded your Ubuntu system to xenial.
Kind Regards,
Bas
