[Qgis-developer] New latlontools plugin
Richard Duivenvoorde
rdmailings at duif.net
Fri Jun 10 00:03:52 PDT 2016
C Hamilton schreef op 2016-06-09 22:40:
> Richard,
> I have published/uploaded it, but figured since it duplicated some
> capabilities I needed to explain why. This is the plugin link.
> http://plugins.qgis.org/plugins/latlontools/
> Pardon me if I don't quite know the correct procedures. I am new to
> QGIS development and am just learning how to work with the community
> and what is expected.
Hi Calvin (sorry I called you Chris :-( ),
No worries, you are actually doing great!
It's just that I could not find (even an unpublished) version of your
plugin on plugins.qgis.org at the time of writing...
Thanks for explaining. You are actually very right to explain WHY you
created the plugin, because with the proliferation of plugins with about
the same functionality we try to be a little more picky on which plugins
add something new. Or else we try to convince authors to share energy
and merge or add stuff to an older plugin.
After approval (mostly done by Paolo) it will be picked up by the plugin
manager (that is it will be available in the
http://plugins.qgis.org/plugins/plugins.xml?qgis=2.14 xml...
Regards,
