[Qgis-developer] Layer Name and originalName, was: [QGIS-Server] Add a Short Name to layers for OGC Web Services
René-Luc Dhont
rldhont at gmail.com
Fri Jun 10 00:51:39 PDT 2016
originalName returns name
name returns name with upper case for the first letter if an option has
been activated.
Regards
Le 09/06/2016 23:34, Germán Carrillo a écrit :
> Does anybody have any thought on this?
> 2016-06-01 10:31 GMT-05:00 Germán Carrillo <carrillo.german at gmail.com
> <mailto:carrillo.german at gmail.com>>:
> Hi All,
> what is the purpose of originalName() method in QgsMapLayer class?
> Documentation states:
> Get the original name of the layer.
> Returns
> the original layer name
> Which perhaps isn't clear enough.
> Plugin developers reading the API would generally expect
> originalName to preserve the name the layer was given when it was
> first loaded into QGIS. And it might be so, except for this line
> (http://qgis.org/api/2.14/qgsmaplayer_8cpp_source.html#l00117)
> that modifies the originalName private variable.
> Am I getting it wrong? Is id() supposed to fulfill such requirement?
> Regards,
> Germán
> 2015-12-08 6:33 GMT-05:00 René-Luc Dhont <rldhont at gmail.com
> <mailto:rldhont at gmail.com>>:
> Le 22/09/2015 13:36, Paolo Cavallini a écrit :
> Il 22/09/2015 13:24, Tom Chadwin ha scritto:
> Many apologies - you are right. I change "Layer name",
> and couldn't
> understand what Display as was meant to be: a
> non-editable text field which
> mirrors Layer name? Why?
> agreed, an old issue, I also do not understant its use.
> all the best.
> It's not an issue :-)
> In QgsMapLayer there are originalName and name.
> The method setLayerName sets originalName and name.
> The attribute name is the capitalize originalName if the
> settings "/qgis/capitaliseLayerName" is set to True.
> In the Layer properties the originalName and Name are
> displayed and the originalName is the editable attribute.
> René-Luc
> Qgis-developer mailing list
> <mailto:Qgis-developer at lists.osgeo.org>
> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> http://twitter.com/GeoTux2
> http://about.me/germancarrillo
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
> |\__
> (:>__)(
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160610/d1cf24d3/attachment-0001.html>
