[Qgis-developer] compile qgis in debian 8
Richard Duivenvoorde rdmailings at duif.net
Tue Jun 14 13:47:45 PDT 2016
On 14-06-16 19:12, BOKU wrote:
> Hello i try to compile Qgis, source from git, in debian 8
> ccmake.. runs fine
> make -> without any trouble
> ./output/bin/qgis
> Speicherzugriffsfehler
> any Idea what is causing that?
> i compiled with compiled versions of
> gdal 2.2.0
> proj 4.9.2
> geos 3.5.0
> libspatialite 4.3.0.a
> spatialindex 1.8.4
> qwt 6.1.2
> qwtpolar 1.1
> grass 7.0.4
Did you try out the stuff I and Matthias proposed at the user-list?
What was the conclusion for this?
Did you have other versions installed from libs or QGIS?
Did you add several repo's?
Regards,
