[Qgis-developer] The first column in the attribute table
Matthias Kuhn matthias at opengis.ch
Fri Jun 17 10:19:45 PDT 2016
Hi Andreas,
as of today there's also the feature id shown in the tooltip of the
attribute table's column header. I think this will help one or another
developer once in a while.
Matthias
On 16/06/16 10:34, Neumann, Andreas wrote:
> Thank you, Matthias!
> I will test it.
> Andreas
> On 2016-06-16 09:35, Matthias Kuhn wrote:
>> Sure, you are right,
>> Sorry, the commit message was wrong but the code is ok.
>> Matthias
>> On 06/16/2016 09:28 AM, Neumann, Andreas wrote:
>>> Hi Matthias,
>>> Column header numbers? Aren't we discussing row header numbers?
>>> Andreas
>>> On 2016-06-16 09:25, Matthias Kuhn wrote:
>>>> Hi Andreas
>>>> It took me less time than it took me to write this email
>>>> https://github.com/qgis/QGIS/commit/9f704d6e92b922555bddb3a5a648edaac2aedf34
>>>> Matthias
>>>> On 06/16/2016 09:18 AM, Neumann, Andreas wrote:
>>>>> Hi Matthias,
>>>>> If there are no negative side effects - I'd like to see the same
>>>>> behaviour like in spreadsheets - an always ascending list,
>>>>> starting from
>>>>> 1 - regardless of the order of the rows.
>>>>> Would this be a lot of work to change this?
>>>>> Andreas
>>>>> On 2016-06-16 09:06, Matthias Kuhn wrote:
>>>>>> Hi Andreas,
>>>>>> I always thought that they are the feature ID. But not even that,
>>>>>> often
>>>>>> they are "feature id - 1", but that's not guaranteed at all.
>>>>>> We could make it match the feature id. Or the current index in
>>>>>> the table
>>>>>> like you propose.
>>>>>> Matthias
>>>>>> On 06/16/2016 08:56 AM, Neumann, Andreas wrote:
>>>>>>> Hi,
>>>>>>> I'd like to discuss an issue in the attribute table.
>>>>>>> There is this very first column (not stored in the provider) which
>>>>>>> lists
>>>>>>> the features as they appear in the provider (by default, if not
>>>>>>> re-ordered by the user). What are these values? Some internal ID not
>>>>>>> present in the data? Or some internal ID from the qt table widget?
>>>>>>> I am just wondering, because regarding this first column, QGIS
>>>>>>> behaves
>>>>>>> different from Spreadsheets.
>>>>>>> When you reorder the table in QGIS, this very first column
>>>>>>> becomes "out
>>>>>>> of order" - spreadsheets always display 1 to xxx - nicely ordered -
>>>>>>> regardless of the sort order. Could QGIS be aligned to the
>>>>>>> behaviour of
>>>>>>> spreadsheets or is there a particular reason not do so? I think,
>>>>>>> from a
>>>>>>> users perspective, because these numbers are not present in the
>>>>>>> data,
>>>>>>> that it would be more useful if they always stay ordered from 1
>>>>>>> to xxx
>>>>>>> or 0 to xxx, regardless of sorting.
>>>>>>> Thank you for your feedback.
>>>>>>> Andreas
>>>>>>> _______________________________________________
>>>>>>> Qgis-developer mailing list
>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>> <mailto:Qgis-developer at lists.osgeo.org>
>>>>>>> <mailto:Qgis-developer at lists.osgeo.org>>
>>>>>>> <mailto:Qgis-developer at lists.osgeo.org>>>
>>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160617/34626b35/attachment.html>
