[Qgis-developer] The first column in the attribute table
Matthias Kuhn
matthias at opengis.ch
Fri Jun 17 10:20:37 PDT 2016
s/column/row/
On 17/06/16 19:19, Matthias Kuhn wrote:
> Hi Andreas,
> as of today there's also the feature id shown in the tooltip of the
> attribute table's column header. I think this will help one or another
> developer once in a while.
> Matthias
> On 16/06/16 10:34, Neumann, Andreas wrote:
>> Thank you, Matthias!
>> I will test it.
>> Andreas
>> On 2016-06-16 09:35, Matthias Kuhn wrote:
>>> Sure, you are right,
>>> Sorry, the commit message was wrong but the code is ok.
>>> Matthias
>>> On 06/16/2016 09:28 AM, Neumann, Andreas wrote:
>>>> Hi Matthias,
>>>> Column header numbers? Aren't we discussing row header numbers?
>>>> Andreas
>>>> On 2016-06-16 09:25, Matthias Kuhn wrote:
>>>>> Hi Andreas
>>>>> It took me less time than it took me to write this email
>>>>> https://github.com/qgis/QGIS/commit/9f704d6e92b922555bddb3a5a648edaac2aedf34
>>>>> Matthias
>>>>> On 06/16/2016 09:18 AM, Neumann, Andreas wrote:
>>>>>> Hi Matthias,
>>>>>> If there are no negative side effects - I'd like to see the same
>>>>>> behaviour like in spreadsheets - an always ascending list,
>>>>>> starting from
>>>>>> 1 - regardless of the order of the rows.
>>>>>> Would this be a lot of work to change this?
>>>>>> Andreas
>>>>>> On 2016-06-16 09:06, Matthias Kuhn wrote:
>>>>>>> Hi Andreas,
>>>>>>> I always thought that they are the feature ID. But not even
>>>>>>> that, often
>>>>>>> they are "feature id - 1", but that's not guaranteed at all.
>>>>>>> We could make it match the feature id. Or the current index in
>>>>>>> the table
>>>>>>> like you propose.
>>>>>>> Matthias
>>>>>>> On 06/16/2016 08:56 AM, Neumann, Andreas wrote:
>>>>>>>> Hi,
>>>>>>>> I'd like to discuss an issue in the attribute table.
>>>>>>>> There is this very first column (not stored in the provider) which
>>>>>>>> lists
>>>>>>>> the features as they appear in the provider (by default, if not
>>>>>>>> re-ordered by the user). What are these values? Some internal
>>>>>>>> ID not
>>>>>>>> present in the data? Or some internal ID from the qt table widget?
>>>>>>>> I am just wondering, because regarding this first column, QGIS
>>>>>>>> behaves
>>>>>>>> different from Spreadsheets.
>>>>>>>> When you reorder the table in QGIS, this very first column
>>>>>>>> becomes "out
>>>>>>>> of order" - spreadsheets always display 1 to xxx - nicely ordered -
>>>>>>>> regardless of the sort order. Could QGIS be aligned to the
>>>>>>>> behaviour of
>>>>>>>> spreadsheets or is there a particular reason not do so? I
>>>>>>>> think, from a
>>>>>>>> users perspective, because these numbers are not present in the
>>>>>>>> data,
>>>>>>>> that it would be more useful if they always stay ordered from 1
>>>>>>>> to xxx
>>>>>>>> or 0 to xxx, regardless of sorting.
>>>>>>>> Thank you for your feedback.
>>>>>>>> Andreas
>>>>>>>> _______________________________________________
>>>>>>>> Qgis-developer mailing list
>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>> <mailto:Qgis-developer at lists.osgeo.org>
>>>>>>>> <mailto:Qgis-developer at lists.osgeo.org>>
>>>>>>>> <mailto:Qgis-developer at lists.osgeo.org>>>
>>>>>>>> List info: http://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>> Unsubscribe: http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20160617/d355daa3/attachment-0001.html>
